frame
I have two question. In my programme, there are 10 frames, if
1) I don't want to run the whole codes in one frame, but i still want to keep the others in the frame, like use // in C to shield some codes.
2) if i want to jump from frame 2 to frame 5, is there a method to do that?
(2,559 Views)
1. Starting with LV8 there is a feature to comment code out.
Otherwise use a case thats fed with a boolean constat of, say, True. Put your code into the false case and leave the true case empty.
2. Not that I am ware of, at least in a direct way. Thats a perfect example for using a state machine. Search the examples!
Greetings from Germany!
Uwe
(2,555 Views)
