fprint in labview
I made a data converting program.
The original data should be written in "fwrite (&arrImageData[iCol][iRow], sizeof (double), 1, pDestinationFile);" in Windows c++.
I got to know there somethings to consider such as Endian problem.
Anyway, Does above fwrite can be realized like this (pic) for an array?
(It's not worked now.)
메시지가 04-27-2009 07:44 PM
에 labmaster에 의해 편집되었음
(3,839 Views)
In what way is this not working?  Are you getting an error message?
What are you expecting to get versus what are you actually getting?
(3,815 Views)
I convert the float numbers to 2 byte integer.
The minimum (-1.293) and maximum (1.688V) are -32768 and +32767 respectively.
The application shows the image rightly, but the Z scale -1.09 and +1.67 for min and max.
In the manual of application said "The data is read as a matrix Number of columns x Number of rows two-bytes data"
Does this mean the application can accept only 2 byte integer? or what else?
(3,787 Views)
That's what it sounds like to me. An I16.
What is this application and where is its manual?
(3,784 Views)
Thank you for the reply.
The application is used to see an image.
The manual is in http://www.nanotec.es/products/wsxm/file_structure.php.
Or you can see the expression in C++ in http://www.nanotec.es/products/wsxm/file_format_examples.php
I confirmed the header of image was correct.
I would like to know the 2bytes binary format clearly.
메시지가 04-28-2009 12:29 PM
(3,773 Views)
According to the C code it's a 2D array of "double"s, which are 8 bytes each. The LabVIEW DBL is the same. However, according to the C code, it's column, row. In LabVIEW, 2D arrays are row, column. So, try transposing the array.
Also, there is no need to use 2 loops to write the 2D array. Just wire the 2D array directly to the data input of the Write Binary File function.
(3,761 Views)
You and I was right.
(3,736 Views)
