fpga
hello,
I have installed  a FPGA card on labview 8. I have upgraded labview 8.0.1. Must I upgrad FPGA ?
Emmanuelle
(6,881 Views)
Hi Emmanuelle,
There is no FPGA 8.0.1 module. You dont have to upgrade. Have a great day!
Prashanth
(6,862 Views)
I have done a simply program to be sure that I manage to have a digital outpout. I plugged a voltmeter at the outpout of the channel of the SCB-68 to check it worked. But it didn't work. I used the connector 1 (DIO). I was aware that on the VI, I had only the connector 0 to add the DIO0 (FPGA I/O).  I think that can explain the fact my program doesn't work. Should I be right, what can I do to make appear the connector 1 I need.
Emmanuelle
(6,850 Views)
It's ok, I've found the answer of my problem....
Emmanuelle
(6,835 Views)
