fpga
Hello guys ,
                  how can I can I realize a smoothing  filter in fpga as my signal is dc and its with noise Since I need the filtering and averaging to be done very quick .
(3,427 Views)
Can you quantify 'very quick'?
Rather than try filtering, is it feasible to remove the noise from source? A filter will introduce delays
If noise is picked up along the signal path, you could amplify the source and increase the signal to noise ratio.
Given a quantified sample rate, would your FPGA be able to oversample and average?
Have you looked at the vi.lib filtering VIs?
_____________________________
- Cheers, Ed
(3,417 Views)
Accepted by topic author Rameshs
hi yenknip,
                  i cant use an amplifier near the source since its a very just environment , amplifier will surely fail. and i want the manipulation in fpga to be done in more than 10 mhz since the whole process is being done within millisecond . i use c series 9205 data to acquire the data.
(3,414 Views)
