fpga
I am getting an error when I try to run my FPGA code from my development computer.  The FPGA code compiles without error, but when I try to run it, I get a window that pops up and says:
"LabVIEW FPGA called another software component, and that component returned the following error:
Error Code: -52008
An unexpected operating system error occurred."
Does anyone know what might have caused this and tell me how to get rid of it?  I am using LabVIEW 2010 SP1 on a Windows 7 laptop and targeting a cRIO-9073 chassis.  (a screen shot of the window is attached)
(2,604 Views)
John,
I am not familiar with this code, but have you been able to isolate or narrow down where the problem occurs?  Could you provide a simplified version of your code that reproduces the same error?
I'm sorry I don't have more information for you at the moment.
Drew T.
Camber Ridge, LLC.
(2,591 Views)
I don't know why, but the problem was not there the next day.  The laptop had been turned off overnight, and the chassis had been powered off overnight, but I had done both those things the previous day.  Since then, the problem has not come back.  So I am just hoping for the best.
There really was no further information that I could give you.  The code was about as simple as could be, just a PWM line and a digital on/off line.  It was a cRIO-9073 chassis with a 9401 module.  I'm not going to worry about it unless the problem comes back.
(2,582 Views)
