fpga using the clock of the CRIO chassis...
Hi.
I am designing an application to acquire data using FPGA. I am using an CRIO-9074.  First at all, I want that the stamp of time for the records COME FROM THE CLOCK OF THE CHASSIS and not from the PC's one, because when the application be finished, the CRIO is going to connect directly to a network, without using a pc.  I would like to use the Time Stamp Control. ¿How can I codify this?
Thank you for your time.
(2,556 Views)
When you use the standard LabVIEW date/time functions in code that is running on the cRIO, you get the time based on the cRIO's clock.
(2,541 Views)
Nathand, thank you by your answer. I am going to consider this.
(2,539 Views)
