fpga-problem driving a DC motor using cRIO 9012 and 9505
I am totally new to cRIO and am trying to drive a DC motor using NI cRIO 9012 and NI 9505 drive. I have configured the cRIO using the instructions and have created a project using CompactRIO Motor Control Basics Tutorial. Now, the problem is i cant find the example given in the tutorial.
can some one please post the similar example or another simple VI in 8.2 so that i can test run it ? it would be better if its an open loop beacuse i am not using the encoder.
Shoaib
(3,061 Views)
Hi Shoaib,
Have you seen this tutorial, or is this the one you're referring to? http://zone.ni.com/devzone/cda/tut/p/id/6143
The files are at the bottom....
Jeff | LabVIEW Software Engineer
(3,028 Views)
