fpga memory check
I suspect that I have bad RAM on a FPGA board.  is there a utility or code that I can run to verify RAM on R-series card?
BTW, the reason i suspect the board is, errors in operation for routines that use memory  follow the board in question.
thanks in advance
Stu
Stu
(2,957 Views)
Hi Stu,
We don't have any standard tool for such a check.  What kind of errors are you seeing?  Maybe with more information we can try to troubleshoot this.
Brian A.
(2,933 Views)
The code I am running is similar to the FPGA PID code.  it uses memory instead of shift registers to preserve previous data to allow for multi-channel use.  It would be similar to saying, I am using the FPGA PID tool for 4 channel PID and the third channel is not returning correct information but the other three are.  The identical bit-file on two other cards works correctly.
Stu
(2,930 Views)
Well, there is no "tool" that we use, but you could certainly write your own.  Just make some direct read/write tests and see if you can confirm your suspicions.  There are more troubleshooting type questions I could start to ask (are they the same cards?  you Say what your VI is "similar" to doing, but what is it really doing?  are there actually 4 I/O channels because maybe it is an ADC or something else? etc..) if you want to go down that road.  However, you may want to give NI a call and do this troubleshooting on the phone if you suspect it will end in sending a board in for repair.
Message Edited by Brian_A on 10-13-2008 09:30 AM
Brian A.
(2,908 Views)
