fpga edge detection for triggering
Hey Everyone
I am stumped and I was looking for some ideas on how to fix my problem.  I am using a NI 5761 to collect signals from a couple photodiodes and a PMT, I am also using the PFI line to send a digital signal to trigger a nitrogen pumped dye laser.
The trouble that I am having is using one of my signals from my photodiode to trigger this PFI line.  Below I have attached my VI that I am working on and an example of the raw data that I am trying to trigger with.  I have been able to trigger the PFI line with a true constant and then collect the data from the two photodiodes in parallel.  Now I am trying to trigger the PFI line off the very first peak so the timing can be set for the measurements that I am making.
The reason I have them in separate loops is because now I am looking to achieve parallel data collection between them.  Once I am able to trigger the PFI line off the signal, I will that have to put in an algorithm to calculate a desired time delay from when that first edge is detected to when I need the PFI signal and my laser to fire.
Ryan
(5,036 Views)
Long weekend to mull it over and still stuck...
(4,994 Views)
Hi Ryan,
The NI 5761 examples installed with FlexRIO support for NI-RIO have an example of setting a Data Edge trigger based on an Analog Input value rising above a trigger level. This example can be found in <LabVIEW>\examples\FlexRIO\IO Modules\NI 5761\NI 5761 Getting Started. From here, open the NI 5761 - Getting Started.lvproj and look for the Getting Started VI under the RIO target you are using. The trigger loop looks like this:
The NI 5671 manual also has a good walkthrough of setting this up. You can find a PDF of the manual here.
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(4,986 Views)
