fpga dsp, FFT xilinx block
Hi at all,
I'm working on LabVIEW FPGA in DSP environment and I have some questions about the FFT Xilinx block ( Core gen 7.1 )
My clock is 130Mhz and data run with a clock much smaller ( 1 data every 13 clock cycles )... Data are pushed out from a FIFO and signalled with a Input_Valid signal.
Is there any PIN on the FFT block that allows to insert input data only when the Input_Valid signal is asserted ???
( I tried to connect Input_Valid (FIFO) to Clock_Enable (FFT), but does not work because if there is no data the FFT block is in stall... )
Second, What is the purpose of the fwd_inv_we signal ???
The manual said : Write enable for FWD_INV (Active High).
Actually I have connected the Input_Valid to fwd_inv_we but seem that does not work!!!
To simplify the questions  FFT vi and time diagram have been attachments.
Thanks in advance Simone C.
Message 1 of 1
(2,867 Views)
