fpga disabled code using space on a FPGA
I have a endable/disable diagram for emulation a FIFO during emulation mode. see atached picture.
Does the disabled code use space on an FPGA ( I have not enough space on my 3Mgate FPGA for my program)
I ask this because in some other part of the labview code I had compiling error (in VHDL code) in disabbled laview code.
So it looks like if the disabled code takes space on the FPGA, is this the case?
Frank
(2,862 Views)
The code in disable structure doesn't take space on the FPGA, I use it often and it works.
But in your case, i guess you should disable the for loop too. Because you have an empty loop that have an auto-index activated, and since this part is not disabled, it takes space on your FPGA.
Hope this helps,
Xavier
(2,831 Views)
by the way the  2 for loops is the same loop, I only made a picture with the enable and disable.
Frank
(2,825 Views)
