fpga digitizing speed
Hello All,
thanks in advance for this great forum!!!
my system is a chassis pxi-1042 with a RT controller pxi-8106 and an FPGA 7831-R.
I'm new with LV FPGA and I was trying to create a symple analog input program (I put them in attachments).
the problem is that with signals in the range of 10-20 Hz everything seems to work fine.
If I put in input to the fpga a signal with higher frequency (also only at 50 Hz) the system has strange behaviours, it is like the fpga has a digitizing speed that is not enough.
I set the fpga clock to 40 MHz.
did I miss some settings?
thanks a lot for the support!!
ciao
Mario
(2,525 Views)
Mario,
You may want to pass more than one data point at a time with your DMA fifo.  Also, the write to file function you are using is not the best choice for high speed streaming.
Take a look at this example that Basset Hound put together.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(2,498 Views)
