fpga compile stuck on "Translating" after 2013 upgrade
Just what it says.  I have some code that compiled in 5-10m with 2012, but when I run it today it basically gets stuck on the "Translating" step and never finished (Well, not after the 3 hours I let it run while we went out this afternoon.
Xilinx log below...
(2,915 Views)
Not that this helps with a solution, but it sounds like it might be the same issue reported here http://forums.ni.com/t5/LabVIEW/fpga/m-p/2661531#M793139? "The VI was taking 20-30 minutes to compile in LV2011, but has just completed having taken 1 hr 45 minutes. 1hr 30 minutes of this was spent Translating, and the Xilinx log was stuck with the last line Process "Translate" failed."
(2,903 Views)
Looks like the same problem, thanks.
(2,884 Views)
