fpga compile error
Hi
I'm trying to compile my fpga code onto CVS-1454 and getting this compile error. Thought maybe I haven't installed something, but can't find what. Installed vision, fpga and ni-rio.
Any ideas on what maybe I haven't installed or done? Thanks
Directory specified by the FPGASourceFilesDirectoryPath resource file tag does not exist.
Directory path: C:\Program Files\National Instruments\LabVIEW 8.5\Targets\NI\FPGA\IMAQIO\FPGAFiles
(3,244 Views)
Hi JChec,
In what order did you install these? Try reinstalling te vision software.  My guess is you installed this before the FPGA module, which would cause this problem.  If it doesn't fix it, can you post what versions of each of these you installed?
Cheers,
Brian A.
(3,219 Views)
Accepted by topic author JChec
Hi Brian
Thanks, that solved the problem. Didn't realise the sequence of installation would make difference.
(3,201 Views)
