formula
Hi :
i want to preform this formula Vout=2000mV+(Vin*10)mV using labview , how can in do that
thanks
(3,326 Views)
It can be done with either "native LabVIEW functions" or by using a "formula node". Have you tried to do it yet? If so, post your code, or an image (.png please, no .bmp!). You would have a control for Vin, the mentioned functions, and a display for Vout. Pretty simple LabVIEW stuff, so give it a try.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,313 Views)
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(3,295 Views)
Another option would be to use linear evaluation. 😄
(3,282 Views)
