formula node
Hello
Can somebody help me to convert this matlab code into c code so i can use it in formula node?
wn=30;
wd=30;
zetan=.05;
zetad=.25;
ts=.01;
anum=(wd^2/wn^2)*(4+4*zetan*wn*ts+wn^2*ts^2)/(4+4*zetad*wd*ts+wd^2*ts^2);
(3,397 Views)
Here it is in Labview..
(3,394 Views)
The VI was done without the MathScript Node..
Hopefully I wired it correctly.  I ran it with the numbers you provided..  See attached image for the result..
RayR
Message Edited by JoeLabView on 06-17-2008 07:22 PM
(3,383 Views)
Hi
Thanks for the reply. I could not open the vi because i have older version of labview ( 8.2). Can you post a picture of the vi? I wanted to use formula node because i have few more equations to calculate.
(3,343 Views)
Here it is in version 8.2
(3,336 Views)
