formula node
Helo, how to properly write properti node with shown content? Written content belong to mikroBasic language.
Regards, Vlado
Message 1 of 11
(7,913 Views)
Accepted by topic author California_J
What's funny is if you look at the help window when moused over the formula node, you get avery similar example of what you're asking.
Follow that link and follow the formula node syntax link.
Or, you know, you could use the very simple LabVIEW code version.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 11
(7,900 Views)
Hi Vlado,
please define Y when x is unequal to 150 and 169...
Message 3 of 11
(7,870 Views)
The formula node is slower than just using LabVIEW natives.  You could easly use a simple case structure to do the same thing faster.
Message 4 of 11
(7,840 Views)
Thanks to all of you, I'll try your suggestions for sure. Report is comming.
Regards, vlado
Message 5 of 11
(7,807 Views)
BowenM, I am not able to reproduce your case example. Could you give me some instructions how to put numbers 150 and 169 into it, also case selector is unwired?
Message 6 of 11
(7,745 Views)
  1. Put a case structure on your block diagram
  2. Wire X to the selector terminal (must be an integer, can't be a floating point)
  3. Manually type in each number separated by commas
  4. Make sure the other case is set to Default
  5. Profit
Cheers
Message 7 of 11
(7,734 Views)
Thanks, it works now as expected.
Regards, Vlado
Message 8 of 11
(7,720 Views)
Please mark the reply or replies that best match the solution for your original question. Marked Solutions help others find this post when they have the same issue! Smiley Wink
Cheers
Message 9 of 11
(7,711 Views)
I would be happy to mark a sollution, but I don't see a button with that possibility. So what to do?
Regards, Vlado
Message 10 of 11
(7,627 Views)
