formula node for array
hi
  i want to convert the values of an array using a different formula for each value in the array.     Can i use formula node for this?    if yes how
if no then is there any other method except for extracting each one individually and converting?
Message 1 of 8
(4,555 Views)
How different are the formulas? Can you give some examples?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,550 Views)
And how many elements in the array? Does that vary?
Message 3 of 8
(4,545 Views)
there are 16 elements in the array and the number remains constant (actually they are temp values acquired by a fieldpoint hardware).
the formula is a linear conversion (for example y = m*x + C) corresponding to the calibration curve of individual thermocouple connected to the fieldpoint hardware.   every thermocouple has a different calibration curve and hence every element in the array is converted using a different linear formula.
Message 4 of 8
(4,530 Views)
Are all the formulas polynomials? If so, then just create an array of coefficients (some values might be zero) and feed that to the calculation nodes. Most of the math function primitves are polymorphic. They take arrays as well as scalars. You may not need a formula node or a loop.
Lynn
Message 5 of 8
(4,523 Views)
Lynn - Exactly the direction I was moving in when asking the questions that I did.
Kunal - The basic concept here is that you want to do as much processing as possible treating the array data as an array. For best performance, you should only break an array apart and index through it as a last resort.
Mike...
LabVIEW Champion
Message 6 of 8
(4,517 Views)
All you need is an array of [m] and an array of [C], all the same size as your data arrray. No formula node needed.
(I think that's what mikeporter had in mind above)
Message Edited by altenbach on 07-24-2007 03:38 PM
Message 7 of 8
(4,509 Views)
got it.  it works. thanx a lot
Message 8 of 8
(4,502 Views)
