formula node Error
this is a basic question, I have a formula node in a for loop, and I am getting this errors:Error on line 4 is marked by a '#' character: "...; P2>=P1; X=P2; else# X=0; "
I dont know what it means, i have posted my code from my progra below:
if (P1>1);
    P2>=P1;
X=P2;
else X=0;
am I missing a bracket or something???? Im not sure how to write the formulas in LabVIEW, but basically thats how I would write it in C++.
I have two for loops in my program. Im putting this formula node in the inner for loop. I want to say that if P1 is greater than 1, and then check to see if P2 i greater then or equal to P1, if so then X is given the value P2, if not I want it to exit the loop and iterate the next number in the inner loop.
(3,577 Views)
I think that your formula is very close.  If I got your explanation correct, this is the formula to use:
if (P1>1) {
if (P2>=P1) {
X=P2;
else
X=0;
You need to have the to ifs be explicit or need to
Or you could go the old fashioned route and do it this way:
P1>1 ? ((P2>=P1) ? (X=P2): (X=0)): (0);
But I would stick with the C implementation if you are comfortable with it Smiley Wink
Hope that this helps,
Bob
(3,564 Views)
it works now, thanks for the fast reply
(3,562 Views)
I have a for loop if I connect an indicator to the N (number of iterations ) to it, what does that do?
say i run my program and it gives me data for 5 values does the loop iterate 5 times of does it iterate the values stored in the indicator????
(3,560 Views)
Depending on how the FOR loop is set up (what is being passed in, what it is doing) the # connected to the N terminal tells it how many times to loop. If an array is connected to the input side (left) of the loop and it is set to autoindex (signified by a little square connector with white space in the center), it will loop either the number connect to the N terminal -OR- the number of elements in the, which ever is smaller.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,555 Views)
