format date to dd/mm/yy regardless of windows settings
Thanks Titou
Tried it out with success...
Message 11 of 13
(733 Views)
thanks for your suggestion tst..... appreciate that
Message 12 of 13
(733 Views)
I would like to make a correction. I made a quick test and it looks like modifying the design doesn't return the changed format in LV. Instead, what can be done is using the SQL command Format, which will output the date in the format you request.
___________________
Try to take over the world!
Message 13 of 13
(729 Views)
