for loops and clusters
Hi all,
I should build a cluster containing two I32 controls but while the first one will not change the second should change according to a for loop ie: cluster value = i * function (i=1,2,3,4.....); how can I do this? Can you attach an example please I'm new to labview ....
I tried using a local variable but when I copy it into the cluster its value will not change during operation.
thank you
(3,112 Views)
Hi Mal
Is this the sort of thing you mean ?
(3,105 Views)
Let's try again with Controls rather than Indicators .... doh !
(3,101 Views)
Hello mal:
I suggest that you would use the "Unbundle"/"Bundle" functions for your cluster, and place these functions inside your for loop. Please see attachment for example.
Please inform me if you have any other questions.
(3,101 Views)
Hi again
I've just a little problem ... I'm using Labview 70 and I cannot open your vis (made by Labview 7.1) could you please provide me an image (a gif for example) ?
thank you
(3,081 Views)
Try this. 🙂
(3,077 Views)
