for loop time
One more thing to note is, your time calculation based on the oscillations and the period/frequncy has little to do with execution time of your overall vi. After your signal is generated, the for loop is running for 25000 times, and even though I don't think there are any complicated operations going on inside the loop, execution is still going to take the time based on the configuration of your machine. As
Kudos are (always) welcome for the good post. 🙂
Message 11 of 17
(1,864 Views)
If you convert the Express VI to a regular VI by way of the right click menu, you can see what it going on inside.
Here is a copy of the VI profiler, and you can see the lower level subElapsedTime.vi is taking most of the time.  But I have no idea why.
Message 12 of 17
(1,860 Views)
I had a look at your code now.
I think that the "build graph express VI's" are probably really slow.
I would recommend you to take those out of the loop..
If you want to have an indicator in the loop you should work with a chart, because charts are made to update quickly.
Take a look at this example from the community:
https://decibel.ni.com/content/docs/DOC-21714
There's also an in built tool "Performance and Memory Tool", which can help you to find parts in your code that are slow.
tools/profile/performance and memory..
Hope you're getting ahead!
regards,
adigator
Message 13 of 17
(1,844 Views)
This finishes in 2-4 ms..
cheers
adigator
Message 14 of 17
(1,842 Views)
replacing the mathscript node, moving all constant operations outside the loop, using the wveform more "natural" could result in this:
Btw.:
Did you ever check your formulas in the mathscript node?
quotient = YS * nwaves / YS * npoints = nwaves*npoints !!! Simple pure math...
Your main problems are those repetitive re-calculation of constant values in the mathscript node.
Additionally displaying numbers in indicators takes time. Building graphs, that are never displayed, takes time. Building graphs in a loop generally takes time.
I didn't include your "if i==N-1" statement in my code. It's easy to do with a simple ReplaceArraySubset function - that's up to you!
Message 15 of 17
(1,839 Views)
First of all, thank you very much guys/ladies for all your help!
I have tried your codes, odessy and adigator, and they are much faster, but when I have connected the output to an oscilloscope, I had two problems that i already had with my code:
-frequency is not 80Hz ( something around 5Hz)
-frequency is not constant ( some oscilletions are slightly faster than others)
I really can't understand this. It might be from the code, or from the way I've sent the output to the oscilloscope. I have used daq-assistant>generate signal/analog output, and one sample on demand, placing the daq in the for loop, so I would obtain the Vx in each iteration. Is it a lame way to do this?
I'm sure everything would be easier without the for loop, but I do need to check the Vx voltage, so when it is in certain intervals the pockel cell will be "on" or off.
again, thank you very much for all your help
Message 16 of 17
(1,816 Views)
This is probably due to the way you write the analog output.
DAQ-Assistant executes some low-level code everytime you call it.
In your example, with one-sample mode, the DAQ-Assistant will always create a task, write one sample and clear the task in the loop.
This needs time and leads to your slow program.
Try to only do in loops what needs to be done in loops!
Create the task before the loop, write the samples in the loop, and clear the task after the loop.
Hope this helps,
regards
adigator
Message 17 of 17
(1,781 Views)
