for loop beahviour
hello everyone,
sorry for the stupid question, but I have a problem with a for loop.
In the following scheme
the second "for" loops only once. If i do not connect the two loops, the second for works correctly (and the index i goes rightly to 1 after the execution), while if i connect them the index stops to 0 (so, I have only one iteration instead of two).
Do you know where could be the problem?
Thank you a lot in advance
(2,854 Views)
Hi There,
This is the expected behavior, a loop will only execute when all it's input are available. If you don't wire the 2 loops, then you launch parallel processes>>they will execute as soon as possible. If you wire them , then the second loop waits for the first to be completed before starting.
Matthieu
(2,851 Views)
Please attach an image that shows readable code, or even simply attach the VI. There is no way to tell what is going on from your blurry image.
  • What are the values of the diagram constants wired to the various N's?
  • Which of the tunnels are autindexing? Which one's are plain?
A FOR loop will loop as many times as given by N or by the array size of the smallest autoindexing input array, whichever is smaller. For example if an autoindexing input array is of size=1, the loop will only spin once, no matter what you wire to N.
(2,843 Views)
ok, thank you so much. Now I understood my problem.
ps: sorry for the blurry image.
(2,829 Views)
