for loop array issue
I am really new to programing in labview (started on Monday). I have been following the labview toturials online and in NI website, but I not been able to solve it.
Edit: all of the values in the array are the same.....
Perhaps, someone here can take look at it.
Message 1 of 34
(5,605 Views)
What you want to do?
What you have tried so far? Upload in 2011
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 34
(5,589 Views)
I just to store all the calculated values in the for loop into the array. Please look at the picture attached above
Message 3 of 34
(5,586 Views)
Like I said update yours as its not clear here.
See my attached VI, I am calculating and adding all the calculated value at last
--Ranjeet
Message 4 of 34
(5,582 Views)
Nope.....
still not clear what are you asking
do you want some values after For loop in an array and you are not getting it???????
Message 5 of 34
(5,578 Views)
The vi has lots of sub vi,so I am not sure how to post them all.  I have attached picture of the array values
Message 6 of 34
(5,573 Views)
You can explain the problem what output you are expecting ( and why , where )
and what you are getting
Message 7 of 34
(5,570 Views)
For instance, I run the for loop 4 time:
if I get a value of [2, 5] at the last iteration.
My current array looks like this [2,5,2,5,2,5,2,5], when it should be like this [3,9,5,1,4,3,2,5]
Message 8 of 34
(5,563 Views)
Ok .........
Look at the build array function , you are giving it two values at a time. So it is creating an array of say ( 3, 1)
every iteration your are creating a new array .
So to get full array at output you need to put your tunnel mode as indexing then you will get a 2D array containing all elements.
Lot of explanation beacuse you just started learning LabVIEW.Smiley Very Happy
Message 9 of 34
(5,559 Views)
Nope, it still does not work. Now I getting a 2-d array like this...
[2,5]
[2,5]
[2,5]
[2,5]
[2,5]
Message 10 of 34
(5,555 Views)
