flushing element in queue
attached is the code.
Message 11 of 23
(3,342 Views)
attached is the code!
Message 12 of 23
(3,342 Views)
I do not have the FPGA stuff.
The consumer loop does not contain any thing out of the ordinary.  The Array to Spreadsheet String only takes a few milliseconds to run with a 1000 x 4 array of DBL which is what it appears that you are feeding it.  Each string is 44000 characters (or larger if minus signs appear).  The file Write could slow down as the file grows due to the OS re-allocating space for the file or fragmenting it as it grows.
On the other hand if you are doing that 50 times per second you may have timing issues, especially with the file write.  I ran a little test with the array to string and file write code. It runs 50 iterations (about 1 second of data in your system) in about 150 ms.  I did not do any testing to see what happens as the file size grows.
Lynn
Message 13 of 23
(3,328 Views)
Thanks Lynn for the testing the code. I think this is the file write that slows down the process. Is there any other method for saving data faster?
Message 14 of 23
(3,324 Views)
Accepted by topic author far_nia
Text files are slow. Look into TDMS.
Lynn
Message 15 of 23
(3,321 Views)
To Have Your Cake and Eat It Too, you need to use two Queue functions.  As you already seen, Flush does not return an array of all of the elements.  However, Get Status can return such an array.  So if you want to do both, i.e. get the Queue elements in an array + empty the contents, do a Status (and ask for all the elements) followed by a Flush.
I've used this property of Status to make a convenient "Average the last N elements" VI.  Create an N-element Queue.  As new elements come in, add them to the Queue using Enqueue Lossy.  This ensures that the Queue holds the last N elements (once it gets filled).  Now use the Status command to get all the elements as an Array, do an Array Sum, and divide by the size of the Array (or use the Mean function).
BS
Message 16 of 23
(3,306 Views)
Bob,
I didn't get the idea. could you please post a small sample to represent the idea.
I attached a figure based on your idea, but don't know how to get the all the array from get status block
Message 17 of 23
(3,298 Views)
Lynn,
TDMS is faster but you can have up to 1048576 elements, and it is full after that. with my sampling frequency (51.2 KS) and having 4 channels (12800 samples/sec/ch), it takes only 82 sec to fill the whole TDMS file and losing data after that 😞
Message 18 of 23
(3,293 Views)
This topic was already being discussed here: No data is saved in queue, labview FPGA/Realtime
Message 19 of 23
(3,265 Views)
I will correct my last comment, TDMS is really faster than other txt writing methods (there is no need to change the data into strings which takes time and slows the  logging process), the limited cells in excel is not an issue, it is the excell that has limited cells and doesn't mean that the number of data in tdms cannot be more than 1048576  elements.
I am putting this link for anyone that has the same problem as mine for converting tdms file into readable data in matlab, the simple code easily make the tdms file readable in matlab for further processing of signal.
http://www.mathworks.cn/matlabcentral/fileexchange/28771-converttdms--v9-
Message 20 of 23
(3,206 Views)
