flush text file buffer vi on LabVIEW for ARM (embedded)
I tried this vi because I want to make sure that my data is written in a file, opening and closing the file again and again uses to much time..
So I tried the FILE I/O > flush buffer vi to write the data and still have the reference to a file on my sd card.
but nothing happens!? there's no text in my file!
The same code on the pc works well.
Is this a known issue or am I doing something wrong?
Attached is a screenshot of my code..
23114i1D43083D98C30C66
Wouter.
"LabVIEW for ARM guru and bug destroyer"
(3,682 Views)
still no answer...
Can somebody of NI say if the flush file vi is supported in labview for arm?
Wouter.
(3,604 Views)
I google'd it. someone has found the problem.
KEIL's RL-Flash does not support fflush for SD-cards ( M: )
translated page by google: post #3
http://translate.google.nl/translate?hl=nl&sl=de&tl=en&u=http%3A%2F%2Fwww.tutorials.de%2Fc-c%2F36459...
"Has been settled. I came by a roundabout route to the low-level feature of FlashFS.   The fflush () function is of a type "M" (Memory Card) is not implemented. While it will be returned to the Ok-State 0, but there are no operations on FAT32 performed."
Wouter.
(3,585 Views)
