float to hex string
Hi mom,
you can typecast any datatype to string:
Message Edited by GerdW on 03-25-2008 10:05 AM
Message 21 of 25
(1,323 Views)
Hi Partha,
you can also use hex notation for floats! (You can use any base for floats - integers are just some special floats!)
Example: 24.25 (base10) = 18.4 (base16) = 11000.01 (base2) = 30.2 (base8) = 22.02(...) (base3)
Message 22 of 25
(1,319 Views)
Hi GerdW,
But you cannot enable the HEX Radix for a Sgl/Dbl, right... ?! Smiley Happy
How can you display the Float in its equivalent HEEX, then? Smiley Indifferent
I think I m not getting your point still. Smiley Sad Can you elaborate a bit more?
- Partha ( CLD until Oct 2027 🙂 )
Message 23 of 25
(1,317 Views)
Hi Partha,
yes, the controls/indicators for floats don't provide a hex display. On the frontpanel you see a decimal representation whereas LabView (or the CPU) is using a (kind of) binary representation for calculation...
But mom was asking for a "conversion to hex"! And you can convert floats to hex "display" (string!): division by base for integer part, multiplication by base for fractional part, concat all digits to a string!
Message Edited by GerdW on 03-25-2008 10:38 AM
Message 24 of 25
(1,310 Views)
Would that be a bad time to bring up Endianness? 😄
It could certainly be an issue when flattening multibyte data to a string.
Message 25 of 25
(1,284 Views)
