float to bytes conversion using labview
sir now i want to convert bytes into float number now what to do?
Message 11 of 20
(3,821 Views)
Pay someone to do your work for you.
Bill
CLD
(Mid-Level minion.)
Message 12 of 20
(3,811 Views)
It's still the typecast function you want to use, as has been already recommended to you by someone else. Reading online help and searching can go a long way here. The way you do it so far you only annoy everyone.
Rolf Kalbermatter  My Blog
Message 13 of 20
(3,802 Views)
A few simple explanations can be found here.
Message 14 of 20
(3,775 Views)
sir i have done the ist part of that float to bytes now the reverse of that is not successful. means i gave input float to type cast function and unsignbytes aray and get the unsignbytes aray now i want to get back my float number using type cast when i give input unsignbytes aray or i convert ist unsignbytes aray in to hex strings to the typecast function and float to the type i m nto getting the same float number kindly tell me what to do
Message 15 of 20
(3,739 Views)
Accepted by topic author ranazeeshanali
Did you wire a float (double) constant to the Type input of the second typecast?
Lynn
Message 16 of 20
(3,727 Views)
Show your code! One or both of your type casts does not have the correct data type specified but without seeing what you did, it's impossible to tell.
Message 17 of 20
(3,726 Views)
thnx to all of u my problem solved thnku so much to all of u again
Message 18 of 20
(3,702 Views)
thanku so much sir problem is solved
Message 19 of 20
(3,698 Views)
That you did not figure that out for yourself suggests that you do not keep the Context Help window showing. When you move the cursor over an icon on the block diagram, the Context Help window shows all the connections to the node and gives a brief description of the function. It also has a link to more Detailed Help. This is not only a useful troubleshooting tool but a great way to learn about the functions and VIs in LabVIEW.
Lynn
Message 20 of 20
(3,675 Views)
