flexrio stream to disk
I am looking for an labview example  that shows how to acquire data with a strobe clock and streams the data to a file on the computer
How can I determine what the maximum clock rate is for the data clocked by the strobe signal?
(3,367 Views)
Tiger,
What type of flexRIO are you using?
Also, what exactly do you mean by "strobe clock"?
Daniel
(3,336 Views)
Tiger,
To best help you, in addition I will also need the following information about your setup:
1.) Adapter Module
2.) FlexRIO
3.) Chassis
4.) Controller (Mxi or embedded)
In general, the max data rates you will see for a PXI FlexRIO is 100MB/s and PXIe is 700MB/s.  You can go faster, but those are good, safe numbers.
Daniel
(3,314 Views)
NI PXIe-1082
NI PXIe-7962R
NI 6587
NI PXIe-PCIe8375
SMA-2164 with coax cable for loopback
I want to use the strobe input for clocking of receive data
Additionally would like to use the channel serdes and stream each data channel to separate files
I assume the the 700MB/S is per DMA stream(channel) or is it the total bandwidth for the instrument?
(3,290 Views)
Tiger,
Those values actually relate to the entire bandwidth of the device- not per channel.
(3,278 Views)
I imagine that the bandwith of the write speed of the instrument is actually limited by the hard drive
(3,274 Views)
Tiger,
Possibly.  I guess you could think of the drive as the data sink side of the transmission.
You could design a system that buffered into RAM before writing to the drive if the drive was the limiting factor.
Daniel
(3,262 Views)
