12-26-2017 10:53 PM
Hi all,
After I installed flexRIO, in my LabVIEW, I could not find any flexRIO in VI
Please help.
Thanks.
Solved! Go to Solution.
12-27-2017 07:05 AM
You're going to have to give us a whole lot more than that if you want us to be of any help to you.
What FlexRIO are you using? What PXI controller? Which version of LV and the drivers did you install?
What do you see in MAX?
Did you add your target to your project?
01-02-2018 07:50 PM
The problem solved, thanks for the reply.
01-02-2018 08:58 PM
In order to help others who in the future might have the same problem and search for an answer, you should tell in your message how you solved your problem.
01-02-2018 11:13 PM
I just copy the file in other PC and transfer it to the PC that has the problem and it works well.
