flashing a microcontroller through CAN
Is there a way to accomplish this on TI C2000 32 bit microcontroller and LabVIEW DSP module?
Thanks.
(3,170 Views)
The following knowledgebase article lists the hardware that LabVIEW DSP supports: http://digital.ni.com/public.nsf/allkb/AF9886D62684C05D86257101007F4647?OpenDocument .
Hope this gives you the information you need.
Vivek Nath
Machine Vision
(3,151 Views)
Thansk for the reply.
It's not clear from the link whether flashing even the supported boards through CAN is possible. Does this mean the answer is no?
If the DSP module is not the right tool, are there third party tools available that cna do this?
Thanks.
(3,144 Views)
I am not sure what you were referring to by 'flashing a microcontroller through CAN'. There is no specific add-on that we have for NI-CAN to work with microcontrollers. I may be able to help you further if you could elaborate on what exactly you are trying to do.
Vivek Nath
Machine Vision
(3,111 Views)
