fixed Y axis range with Auto minimum or Maximum in waveform chart
     I am trying to wire a code for waveform chart. I need Y axis to have a fixed range, while minimum or maximum value following plot or auto scale. Is it possible? Also I need to show difference in points (y-axis value) in chart for a constant period of time (x-axis). Please help me.
Thank you,
VG
(4,945 Views)
You are trying to accomplish both one task (Y scale fixed range) and its opposite (autoscale) on the same chart. This is not going to happen.
If you want to use a waveform chart, the help screens which come with LabVIEW are really helpful. Give them a try.
You might want to visit the online tutorials listed below for getting started quickly.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(4,943 Views)
That's what I thought too, but I need to check the graph for constant time period if the Y value dropping below certain value (DY/DT). Is it possible to write code for something like this?
(4,941 Views)
Sure. I leave you with the same advice as above. That'll get you started.
Now, if you just want to fix your bottom OR top point with a fixed range to the other, that's quite possible, but it looks like you'll have to roll your own algorithm, I don't see any ready-made properties there. But it'll be easy
Cameron
(4,938 Views)
