fix Graph window size
      I am doing zooming two graph simultaneously.
     From the attached picture, you can see when the plot is zoomed, the change of the Y scale values length makes the plot display area resized.
     How can I fixed the size of data display area?
   LV7.1
Wei Tong
(3,600 Views)
I don't see a picture, but most likely you should right-click the graph (while in edit mode) and unselect "Advanced...Auto Adjust Scales".
See if this helps.
Message Edited by altenbach on 04-11-2008 10:40 AM
(3,599 Views)
sorry, Here is the picture.
(3,588 Views)
Yes, my solution outlined above will solve your problem. 😄 Have you tried it?
(3,578 Views)
Yes, I tried it, it works. Thanks.
Wei Tong
(3,554 Views)
