fitting data with a square root model
Good day,
I've got an array of data to which I'm trying to fit to the model y = A*sqrt(x-x.0), basically the upper half of a parabola crossing at an arbitrary x-coordinate.  I'd be using A and x.0 as the fit parameters.  What's the best way to define this sort of model?  It's not a standard one as far as my (limited) experience goes.
Thanks for your suggestions!
(3,207 Views)
I'm trying a Lev-Mar approach, but I've never used one before.  My attempt is attached, but the code keeps exploding when I try to run it...
(3,200 Views)
Can you repost your VI with default data saved in the controls?
You might ry expressing your function in terms of y^2 to get rid of the sqrt.  If x-x0 is negative then sqrt will yield NaN.
-Jim
(3,191 Views)
Sorry.  Thought I had...
(3,184 Views)
Are you sure your model is a good match for your data?  Seems off to me.  The Y-values range from approximately -.0006 to .0012, but your model can only generate all-positive or all-negative Y values.
(3,160 Views)
