finding peak or shoulder of a curve
I have an array of PMTs.  In order to set the biases individually, I need to identify a particular feature on a spectral curve and measure where it lies for each PMT.  Due to the different physical characteristics of the tubes, and the fact that the source (Na-22) is not the same distance away for each tube, each energy spectrum is different.  I need to pick out the 511 keV peak, and have written a program which does it well; as long as the curve has a well pronounced peak that is.  For curves where the peak is not pronounced (more of a shoulder than a peak), my program is useless.
Does anyone know of a method for picking out these more subtle features of a curve...even a good third party package?
It has been suggested that I do curve fitting first but I don't know of a formula describing the curve and so have not had much luck with the curve fitting VIs built into LabVIEW.
The attached picture shows a curve with a "good" peak and one which is "bad" and has no pronounced peak.
Any guidance is appreciated.
Message 1 of 13
(6,016 Views)
Take a look at the first, second (maybe even third and fourth) derivatives of the curves to see if your peak or shoulder stands out more.  Maybe even some combination of characteristics from them could be used.
If you like, post the two sets of data you displayed.
Message Edited by rpursley8 on 10-05-2005 09:56 AM
Randall Pursley
Message 2 of 13
(5,985 Views)
Hey, thanks for the reply.  I will do as you suggest and see what happens.  Attached is a little VI to display the two curves.
Message 3 of 13
(5,973 Views)
You could also use limit testing under the waveform monitoring section. It is setup to work with waveforms as the input, but I have hacked it to work with arrays as the input.
Message 4 of 13
(5,969 Views)
Can you save this as a 7.0 format file?? The signal processing toolkit has a denoise and detrend vi that may help also.
Message 5 of 13
(5,967 Views)
unclebump, I don't have7.0....sorry.  Is there a way to make my 7.1 program backwards compatible before saving it?
Message 6 of 13
(5,963 Views)
File, Save with options, Save for previous.
Message 7 of 13
(5,960 Views)
attached is the 7.0 version; thanks for teaching me how to save it with options.
Message 8 of 13
(5,958 Views)
Briefly looking at your data, if you take the first derivative of your data, a local peak would appear as a positive to negative zero crossing, and if there is not an actual peak, then the point you are looking for is the point that is closest to zero but still negative (since the slope of this line is never positive, but gets close at the saddle point).  Don't know enough to know how noisy your data is though.
Randall Pursley
Message 9 of 13
(5,943 Views)
Yes, this is the problem I ran into trying to write my own peak finding algorithm.  When there is no positive-to-negative slope crossing, it becomes had to define a peak.  If I just look for "closest to zero but still negative", I will get a point on the plateau, far past the point I want to locate.  Our eyes can do a pretty good job of finding the  feature in the curve, but it's proving difficult to come up with a decent algorithm since I want the computer to make no assumptions or guesses as to where the point may be...just identify a feature.  Maybe that's my problem....
Message 10 of 13
(5,940 Views)
