find string between two characters -- regex?
So this seems like a regex type thing, but I'm still incredibly regex illeterate. If I have an offset in a string, I want to find all words separated by the space before and the space following that location.
For Example:
"This is a string of multiple characters"
If my cursor was between the o and the f in "of" i would want to return "string of multiple". I can then split this into an array of words using "\s" as a delimeter. I just need to get the substring shown.
(6,352 Views)
Or you split the string at the Offset, reverse the first half, look for the 2nd space in each (which can be a regex, similar to [^\s]*[^\s]*) then revese back and recombine. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,342 Views)
What do you want to happen if the cursor is at the very beginning?
What if the cursor is between the space and the o in "of" (at the beginning of a word)?
I thought "Find Token" would work but I was wrong.
You do end up with a space at the begging of the SubString output if the offset is greater than 0 zero.
Omar
(6,321 Views)
/Y
Droppin' knowledge.
(6,309 Views)
