find serial number of NI Nodes programmatically
while creating the network in NI-MAX, it shows Serial number of Nodes in a different column, so is it possible to get Serial Number of all NI WSN Nodes using Labview Programming in an array from NI-MAX ,if so then how can we do that?
(3,166 Views)
Try this.
Get all devices
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,160 Views)
HI,
Thanks but I need serial number of all I WSN Nodes like 3202,3212,3226 etc.
(3,132 Views)
Hi rita,
that's not the serial number, it's the type number!
And you should find that information in the information provided by DAQmx as shown above. Did you check ProductType and ProductNum?
(3,123 Views)
hi sir,
Ya I tried for NI Node 3202 but unable to do so.I refered to NI Project http://www.ni.com/example/31479/en/  but its not showing correct result.
(3,114 Views)
I tried to access the serial number of the Node 3202 ,but its not showing correct result.Plz help me where I am doing wrong ....
(3,082 Views)
