find path and return image
Hi, i have 3 bmp image files on C:\ and i would like to create a vi that would find those 3 image and find the path of it and output that image then insert into report. how do i do it?
(3,132 Views)
You can use "list folder" from the file i/o palette with pattern *.bmp. It will give you an array of matching file names.
What do you mean by "output" them? Display on the front panel, maybe? What kind of report do you have in mind?
(3,130 Views)
Alright then. i want it to find the path of the image right after that it will attach that image to my report. my report is just a .doc format word file.
Message Edited by Trig on 01-08-2009 07:32 PM
(3,121 Views)
Hi should i use append image to report or append control image to report? pls advice
(3,110 Views)
If the image is one of the supported types, jpg, bmp, emf, wmf or gif.. I should use that function.
Ton
My LabVIEW Ideas
(3,096 Views)
