find newest file in folder
Is there a way to only pull the newest (most current time stamp) file out of a folder?
Cheers!
(3,742 Views)
I think you have no choice but to check the last modification property (using the File/Directory Info primitive) for all the files (which you can get by using the List Directory primitive). You can then use Array Max and Min to find the newest file.
___________________
Try to take over the world!
(3,734 Views)
Thank you for the quick reply!
(3,727 Views)
How about using System Exec.vi with dir/od as command line and check output to get your last modified file at provided directory ?
Maybe that's quicker than the other method... just guessing
(3,721 Views)
