find hardware lists devices not connected
When using the Find Hardware VI, it reports devices that are no longer connected (as does Max).  Even using the IsPresent property, the response is yes.  If I try to open a VISA connection to query it for confirmation of its presence I get an error dialog.  Is there a way to find out which devices are actually connected without generating an error?
(1,461 Views)
You realize, don't you, that you answered your own question.  Suppose you have an array of "All Devices".  Put this Array through a For loop (which gives you the devices "one-at-a-time") and try to access the device.  If you get an Error (because the devices really isn't there), wire a False to the Conditional input of the Output Auto-indexed Tunnel (right-click the Tunnel and make sure that "Conditional" is checked).
(1,447 Views)
Hi Bob.  I'm trying to make the search for the instrument transparent to the user.  I don't want the error dialog to pop up.
(1,438 Views)
Then handle the error so the dialog does not pop up.  Even wiring it up to a Not will work.  The result of that Not can then be used with a conditional indexing tunnel to only keep the valid references.
(1,406 Views)
Accepted by topic author Jim_Marihew
DOH!  I had an error handler, but forgot to wire the "no dialog" to it. 😳
(1,401 Views)
"Clear Errors" also works. Or, set your VI's to not automatically handle errors (File -> Properties -> Execution, IIRC).
(1,380 Views)
