filter from transfer function
Hello
I need to design filter based on the transfer function, the transfer function is:
H= Constant*Wf^2 / (1+Wf^2)
 Where Wf is Fourier transform of window function ( Parzen function)
my problem is how to create the window function in labview and how to use it in above formulla
Regards
(2,667 Views)
Hi Faris,
I've just been looking into your problem for you and it appears that the Parzen window function is included in the Window Sub-pallette of the Signal Processing pallette. You could use this function in conjunction with a formula node (Structures pallette) to create your function, or alternatively you could use labview functions to build up your transfer function.
I hope this helps.
Best Regards,
Chris
National Instruments - Tech Support
(2,635 Views)
Just to add to the previous comment:-
The Window functions are included in all LabVIEW versions apart from LabVIEW base.
Chris
(2,634 Views)
