filter data
Hi
I need to filter some data, its basically ratio values verses time for a temperature sensor. I'm already using an averaging filter but the overall response of the sensor changes. This is shown when you run the attached VI and select the text file. One graph shows prefiltered data while the second shows filtered data. Can you suggest a filter that would filter the data without changing its response, any help at all would be greatly appreciated,
Mary.
(2,623 Views)
Please repost your VI. Second any of the filter Vi's should work.
Joe.
"NOTHING IS EVER EASY"
(2,623 Views)
