filter array
I have 4 inputs channels, each containing 8 values (32 channels), and I want to meanfilter each channel all with the same filterlength...I know this seems like a very newish question, but in that case, the reply should be realtivly easy too 😉
see image for details
Message 1 of 11
(4,629 Views)
Duplicate post
If you need to add more info you can either "Edit the post" or post a reply to your previous post.
Message Edited by Support on 12-04-2007 11:40 AM
André (CLA, CLED)
Message 2 of 11
(4,613 Views)
look at the times, they were posted simultaneously, could not find a delete, flagged it to the moderators...sorry
Message 3 of 11
(4,608 Views)
Hi all,
I removed the duplicate post, so I am sure Tohatsu would appreciate any help given on this thread.
Laura
Web Support & Operations
Message 4 of 11
(4,583 Views)
You could use the point by point VI in the Signal Processing palette.
André (CLA, CLED)
Message 5 of 11
(4,550 Views)
Yes, and that is what I've been doing for testing puropses, but I dont want 32 of them lying around in my VI...but maybe that's the only solution?
Message 6 of 11
(4,507 Views)
Repetitive task with a fixed number of iterations typically call for a FOR loop and one instance of the code. Could you show a bit more of your VI or even attach it?
Message 7 of 11
(4,500 Views)
Message 8 of 11
(4,488 Views)
Bump
tried some for-loops, but it seems I must be doing something wrong...cause all the data is just messed up with this method.
Message Edited by Tohatsu on 12-17-2007 02:49 AM
Message 9 of 11
(4,454 Views)
The NI pt-by-pt mean filter is reentrant, so using it in a FOR loop on 32 channels will not work as expected.  You would still need 32 instances, one for each channel.
The pt-by-pt meanfilter is a plain VI, meaning you can modify it for your own purpose. Make a copy of it under a new name and change it such that it takes an array as input and will do a meanfiltering operation on each element (channel). Shouldn't be too difficult. 🙂
Message 10 of 11
(4,429 Views)
