fill up 1D array with values from vertical pointer slide control
I want to fill up a 1d array while adjusting a vertical pointer slide control. I tried using a user's solution here: forums.ni.com/t5/LabVIEW/build-1D-array-dynamically-with-data-from-for-loop/m-p/758715/highlight/true#M347601 but when I tried it, I only got the current values filling up the array. I want the past values to be just pushed once a new value comes from the slide control. Can anyone help me on this? Thanks.
(3,531 Views)
Hi Spectre,
as usual: show us, what you have done and we tell, what's wrong...
Hints:
Use a shift register and a BuildArray node...
(3,525 Views)
Hi GerdW! This is what I've done so far. I want this VI to be controlled in an "environment" VI, together with other VIs like a buck converter model VI and an algorithm VI that controls the converter. As I said what happens right now is that only the most recent value is filled in the array, what I want is past values to be stored in an array. For a shift register, I should use a while loop right?
(3,511 Views)
Your VI creates a new 3D array with 100k points from scratch containing all identical elements, reshapes it to a 1D array, and then stops. There is no intereacticity. Are you using contiunous mode to run this? (Don't!)
First of all, you are creating way too many dimensions. You would get the same result if you would simply wire the scalar into the inner most loop and leave the initialize array out of the picture or initialize a 1D array of lenght 100k. No loops needed.
Yes, you need an outermost while loop containing a shift register. Initialize the shift register with a 1D array and append new data inside the looop as desired.
(3,506 Views)
I'm sorry, but can you please explain how to initialize the shift register? Do I connect the vertical control to an initialize array, then connect it to the shift register in the while loop?
(3,440 Views)
