fill circles on xy graph
I have a VI that draws circles on a XY graph. These circles represent the position of a microscope objective. The dwell time of the objective is increased, and I would like to fill the circles with color intensity that is related to this increase (I am using LV 8.0).
Thanks in advance,
Gaby
(5,473 Views)
You might do better with a picture control if you are interested in a picture of circles, there is a draw circle and you can select color of the fill.  filling plots is difficult since you are reallu filling between an axis and a plot or possible between 2 plots.
did you know that graphs have a built in set of picture controls as a property node called plot image (front middle back) that lets you draw dirrectly onto your plot.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(5,465 Views)
Your VI using something called Stuff:\LabView games\Control Program\Linspace.vi
When I load it into LV 8.6.1, it finds a different vi called "Linspace" deep in the VI lib, which does something completely different.
I suggest you rename your VI to not conflict with the system, and possibly include it here.
That having been said, an X-Y graph is perhaps not the best place for a filled-circle type of drawing.
I'm not sure when the feature was introduced, but there is now a PLOT IMAGES property for graphs, where you can insert a picture in front of, or behind the plot data.
Consider using a PICTURE control to plot the data and the circles.
If you must use only an X-Y graph, then you have to create a separate plot for the FILL part, consisting of concentric circles around the center point, and colored the way you want.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(5,463 Views)
Simply add a second plot with the points in reverse order and use 'Fill To'.  See quick example, I could spend longer cleaning up the code, but I'll leave that up to you.  You may also want to tweak the colors, I didn't bother.  In principle it uses twice as many points as necessary since each plot only needs to be a semi-circle.
(5,432 Views)
