file read
I need to transfer text file from one PC to another PC using RS232 cable. I designed the block using VISA and I am stucked with FILE READ. Kindly help me to fix this issue.
(3,595 Views)
You need to supply a file to save the data to.  For the Bytes to Read, just wire that to the Bytes At Port.  I would also make sure the serial port is NOT configured to have a termination character.  And you shouldn't have a While loop around this code.  You only need to send that file once.
(3,558 Views)
I dont know what block will connect to the filename in READ function.
(3,551 Views)
I connected the control to the filename. I am getting this error. I need the file to be saved in location of another PC.
I attached the screenshot of the error message for your reference
Pls help me
(3,544 Views)
Hi ummy,
to "save in location of another PC" you need to execute this code on that other PC!
One PC acts as sender/server, the ohter PC acts as receiver/client. Both need appropriate software to handle communication...
(3,527 Views)
To run application.exe in PC. Do you need LABVIEW tool
(3,484 Views)
You need the appropriate run time engine and any hardware drivers (i.e. NI-VISA).
(3,464 Views)
