file not saved
Hi There,
     I can't save my file with this output method. but it works for other programs. Why is that?
     Lei
Message 1 of 10
(5,171 Views)
You are traying to save to C:\Data\2010\081810. This folder must exist and the logged in OS user must have the rights to write to this folder.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 2 of 10
(5,163 Views)
Thanks for the reply.
I have the right and I can save the file in the same folder with other programs.
Lei
Message 3 of 10
(5,156 Views)
Are you getting any kind of error message?  And if so, what does it say?
Message 4 of 10
(5,139 Views)
no error messages..........
Message 5 of 10
(5,121 Views)
Have you done any debugging?  Try highlight execution, or put some probes on the wires.  See if your code is ever getting to the part where the data is supposed to be written out at the Write to Spreadsheet file VI.  Maybe your execution is getting blocked in one of the those subVI's.  I can't tell because I don't have your subVI's.
Message 6 of 10
(5,116 Views)
I found the problem. because it only saves the files when you finish all the loops. If you stopped in the middle, it doesn't work.
Thanks all.
Lei
Message 7 of 10
(5,102 Views)
How were you stopping your program?
You have a stop button control on your front panel.  Wasn't that working?
Please don't tell me you were hitting the Abort button on the toolbar.
Or was it that you have the entire program wrapped in big For Loop, so it ran several more times.  You might want to consider using the conditional stop button on that for loop.
Message 8 of 10
(5,098 Views)
Hi ravens,
   I hit the abort button. Thanks so much for your suggestions.
    Have a nice weekend,
    Lei
Message 9 of 10
(5,090 Views)
Don't do that.  Smiley Wink
See here.
Message 10 of 10
(5,081 Views)
