file dialog can only handle a limited amount of multiple selections
Hi friends,
I found that the file dialog of LV8.20 can only handle a limited number of multiple file selections. I can not open/select more than 750 file at one time. Is there any solution to select more than this at once?
Cheers.
Ronny
(2,753 Views)
Dear Ronny
Which file dialog VI are you using? I tried the 'File Dialog' Express-VI and
could easily open 800 files.
Best regards
Philipp Roessler
(2,738 Views)
Hi Philipp,
thanks for your answer. You are right. I didn't used the express file dialog VI. I chnaged it to the express Vi but it still doesn't work. I found out that it's not related to the number of files but it depend rather to the length of the file names.
I tried to open 1020 files with filenames that have about 20 - 30 characters. I only able to open about 760 files with the express file dialog VI. After that I've changed all filenames just to number from 1 to 1020 and I was able to open all files.
It seems that the lengthes of the filename strings are the limiting factor. Strange and not quite usefull, isn't it?
Cheers.
Ronny
(2,719 Views)
Have you looked at the length of the path as well, an interesting thing to test is to flatten the array of paths into a string and see the string size, I think there is some limit (maybe at OS side?)
Ton
My LabVIEW Ideas
(2,716 Views)
