file added in an executable
I'm trying to create an executable of a VI that analyze a song. I really need that specifically song to be part of the executable. Is there a possibility that when an installer is created you can add the song and always use the sane path do the user doesn't have to look for the file?
If someone could help me, it would be great.
Thanks in advanced.
(2,964 Views)
Hi rrr1,
add the file to your build specs and place it in the standard "DATA" folder of your executable. So the file will be always placed in the DATA subfolder of your executable path and so you're able to load the file from always the same (relative) path...
Idea: When the song data is really static you can preload it at development stage into a block diagram constant and save it as constant data inside a VI.
(2,959 Views)
I love the idea but actually don't know how to make a song a constant. I think I have to show always the path.
Can you tell me how to create the constant please? I would love to know how to do it because the song is really static.
I'm really sorry to bother you this much.
Thank you really much.
(2,937 Views)
Load the song to a waveform or array indicator, change to constant.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,932 Views)
