file I/O and signal processing
I am a beginner to Labview.
There is a 1000 by 2 matrix in a file(ASCII) which should be extracted to
the Labview program. This file contains a signal with time base, which is to
transformed to the frequency domain. What I would like to do is,
1. Graph of the original signal (like a chart in Excel) - time based
2. Graph of the FFT - frequency based
What I wonder is
3. how to extract the original file, and what type it has to be converted
to for the signal processing.
4. whether the range of the time is changeable for the FFT by using the
mouse on the graph 1.
5. whether the above procedure is done sequentially for tens of files.
Please help me.....
Thanks.
(7,435 Views)
Hello
look at the examples that use spreadsheet string to array.
In fact read the whole file into one string, pass that string to
spreadsheet string to array and you should be ready.
A possible problem could be the element separator.
Default it is a tab.
connect an array of doubles (or integers).
When your data is equidistant simply feed the appropriate data to the
fourier transform.
Look at the fft vi for what you need more.
succes
time based
> What I wonder is
> Please help me.....
> Thanks.
Albert Geven Philips Research Laboratories Eindhoven
Building: WAAp 120 Prof. Holstlaan 4
Phone: +31 40 2743019 5656 AA Eindhoven
Fax: +31 40 2744810 The Netherlands
mailto:geven@natlab.research.philips.com
(7,434 Views)
